While we are at it. If you use a square taper bb can you use any old crank set?
Yes and no.
Yes you can, you just keep getting bigger and bigger BB’s until you have clearance between chainring/chain and chainstay/tyre.
No you can’t, some fat bike cranks have the chainline shifted out but the arms are straighter to keep the Q factor sensible, a bit like the current ‘boost’ standard. This means that some fat bike cranks don’t fit on some fatbikes (the first batch of On-One Trail’s had issues IIRC and had to be sent back, as well as others). So while it may fit, some combinations may result in a ridiculous Q-factor if you’re building a 120mm BB for 5″ tyres, 100mm BB/4″ tyres the worst that’ll happen is the Q-factor is almost as wide as a 120mm BB.
That and Royce BB’s are as much/more than a cheap chainset. And niche enough that there’s probably a limited 2nd hand market so you can’t make your money back on them.
