Hola,
As much as I love my 2006 banana yellow FSR Pro, the constant bobbing on climbs has finally got to me. I've tinkered with air pressure, rebound rate and brain fade constantly, but without ever getting it to a sweet spot. I know it's not an Epic, but the minimum level of travel is annoying. I have a fairly smooth pedalling action, so it's not caused by me stomping up and down on the pedals. For such a great bike, it's a tragedy how much it gets left behind when I take my hardtail out instead.
I was about to flog the frame off and replace it with a Ti hardtail, but someone recommended replacing the Brain/Fox rear shock with an RP23. They've got one on their Orange and everything they said about its range, from almost rigid to active plushness, sounded like what I needed.
Has anyone taken the same route? Is there anything I need to be aware of? Spesh's site says the 2006 FSR Comp has a 7.5" x 1.75" Triad. Is this equivalent to the 190mm x 50mm RP3, or are they incompatible? Am I a crazy fool to even consider it?
