Viewing 10 posts - 1 through 10 (of 10 total)
  • Stuff inside a woodburner
  • trout
    What is the lining of a woodburner made of
    the back plate in mine has cracked in half and need to get a new one
    wrightyson
    Varies. Mine are cast plates, others are fire brick material which you can buy in sheet form and cut to required size.
    Mine was an absolute **** of a job to replace that lost me the skin on several knuckles.
    trout
    It seems like a very lightweight material of little strength
    but glows redhot when in use like some sort of fibreboard
    wrightyson
    Firebrick sheet.
    Probably cheaper at a local supplier.
    mj27
    Vermiculite board. It is light, brittle and hard to find at a good price
    Wharfedale
    Troutie meritt and fryers sell vermiculite sheets which can be cut to size.
    You can also get a bit more life out of them by bonding them back together with some fire cement.
    Yup firebricks going to need to replace mine in the spring.
    sharkbait
    Just because a firebrick has cracked doesn’t mean you need to replace it – it will still work fine.
    Only needs replacing when chunks start falling off.
    trout
    Cheers that Vermiculite looks like the very stuff
    Wharfedale never thought about Merrits
    the back piece broke in half and I bolted it together with steel plates
    but the steel on the flame side has now disappeared
    martinhutch
    Merritt’s is the best! Open til 12 today.
The topic ‘Stuff inside a woodburner’ is closed to new replies.
