sooner rather than later. if it’s hard, you can console yourself that getting it unstuck is as easy as it’s ever going to be (this time round)
What you can try for starters is slacken off the bolt, penetrating oil round the post and slot, and go for a ride, sitting down more than you usually do. A bit of jiggling might do the job for you. Try twisting it with your thighs, too.
If you need more, this is what I did: I don’t know if the coke actually did anything, it’s supposed to dissolve ally oxidation.
– coca cola down the seattube over a weekend
– forcing apart the clamp slot and spraying GT85 (I used the handle of a table knife in an adjutable spanner)
– boiling water round the top of the seattube.
– twist the saddle as hard as you can , bracing the frame with a foot and/or a wall.
– Once you’ve got it moving a bit, then comes the mighty heaving:
– left foot in the downtube/seattube junction, heel of the right hand pushing the back of the saddle towards me, left hand on the nose, pulling and twisting. I won about a millimeter of seatpost per quarter turn, then I had to return it to center for another twist n pull.
– apply more boiling water when it starts to get trickier, every 3 or 4 quarter turns
– repeat as necessary.
wear gloves! I lost skin on 2 fingers and have a big blister in the palm of my hand.
