Viewing 11 posts - 1 through 11 (of 11 total)
  • Stuck Rear Hub Bearing
  • gavjackson1984
    Trying to replace the bearings on my hope pro 2 rear hub and I’m struggling to get the outer disc side bearing out. You are supposed to knock the axle through the drive side and out of the disc side but it won’t budge.
    Any tips for getting it out?
    PeterPoddy
    Hit it harder.
    bruneep
    this
    gavjackson1984
    Tried that didn’t work
    wwaswas
    As above, a bigger hammer is what’s needed.
    Nobeerinthefridge
    Give the axle a good wallop from the drive side.
    wwaswas
    Protect the axle end with a block of wood to stop it getting damaged.
    gavjackson1984
    Cheers, I’ll swop the rubber mallet for a lump hammer and see what happens.
    coatesy
    Rubber hammer’s your problem, drop a large bolt into the axle to prevent damage, bin the comedy hammer, and hit it with a proper hammer.
    z1ppy
    Pop a sacrificial rotor bolt in the end of the axle, to smack, instead of the axle itself, wooden blocks fine but metal on metal will transmit the force better 😉
    gavjackson1984
    Socket on the end of the axle, hit it with a lump hammer, one hit and it was out.
    Lesson learnt… use a big boy hammer.
The topic ‘Stuck Rear Hub Bearing’ is closed to new replies.
