Fellas,
The preload on this fork is coil, its a grey/silver knob and has around 30 clicks of adjustment. There is also an air assist feature sat inside the middle of the rebound dial which can be used to add a little bit more for riders whose weight puts them at the limits of a given spring, however utilising this had been said to cause issues with small bump sensitivty.
The compression for this fork is on the bottom right leg and is not related in anyway to what I am saying.
I appreciate the help but its getting dragged off topic by non factual advice. Take it from me there is a preload adjuster, its grey, its on the left side of the fork, its coil based and its independent from the air assist and compression dials. If you still don’t believe me do a google search before telling me in wrong.
All the best,
Lee.
