OK, so the consensus seems to be to use a soft mallet to tap it out.
If i unscrew the maxle, the fork legs are forced apart and a gap appears between the cup on the hub nearest to the thread end. The hub stays in its original position relative to the maxle itself.
So the question is: what do i tap with the soft mallet? The hub flange? The maxle?
To me if i need to tap anything it should be the hub itself? Does that sound right? And if i do presumably i should hold something like a large spaner wrapped in cloth over the hub and tap the hub on the opposite side to the maxle thread?
If anybody has done this before can they verify what i am saying?
