I’m trying to resurrect an old set of Hope Minis. The original type where the caliper splits in two parts:
http://www.hopetech.com/wp-content/uploads/2014/03/2002MINIcaliperexploded.pdf
I have a set of replacement seals and phenolic pistons. But the issue is I can’t get the old pistons out.
They are a bit corroded looking. The seals were all gubbed so no chance of building enough hydraulic pressure to get them out, so I split the calliper and so far I’ve tried pulling at them with pliers, soaking them in diesel, soaking them in WD-40, pressuring with air, heating them over gas, and whacking them with a hammer.
Any other options I should try before giving up on this retro folly.
