For others referring to this thread …
Yes, don’t forget to make sure that there is no washer in the recess of the crank … you can’t extract the crank past it! Even if one comes out with the bolt, have a look in the crank as well, to make sure no-one has doubled it up in error!
Campag recommend the following pullers, having tested them both in the factory / Service Centre environment and with the teams:
Facom U.301 in combination with FC-UT090 & FC-UT095 (the original recommendation and the one we use in-house at Velotech)
VAR P12600 – we have tested this and it works really well.
Cyclus 720249 / 720310 (carbon crank adaptor) – we also have tested this and again, it works really well.
They have not conducted tests on the Park tool so it’s not recommended. We’ve tried it and the tool failed 🙁
HTH
Graeme
Velotech Cycling Ltd
Main Campagnolo Technical and Service Centre UK
