Viewing 13 posts - 1 through 13 (of 13 total)
  • struggling to bleed a reverb, any tips?
  • theendisnigh
    Bled mine last night after fitting a new cable.
    Used the bleed kit, even glanced at the instructions, but didn’t get it as good as it was pre cable change.
    On full speed it operates slowly. On slow speed it doesn’t operate.
    I guess there is still air trapped.
    Anyone have the same issue and overcome it? Going to try again tonight.
    legend
    Watched the Sram guide on YouTube? Following that was enough for mine
    Edit: and have you checked the air pressure?
    theendisnigh
    no I haven’t watched that, will do that tonight.
    Yes I checked the pressure and it seems ok. I did let all the air out at one point, because the seat post was locked down. But I refilled to 250psi.
    Cheers for the video pointer, that should help.
    Ecky-Thump
    I had problems after replacing the hose and barbs following a breakage.
    Turned out that I hadn’t wound the barb into the hose far enough at the seat end and it was weeping slightly when activated, then presumably allowing air into the system upon “return”.
    Hard to spot because the replacement seat barb is shrouded for protection.
    Once I’d wound it in a bit tighter and re-bled, it was fine.
    The actual bleed itself is very staightforward and hard to get wrong.
    theendisnigh
    actually that might be happening with mine, I bled it good and proper and it seemed to start off ok and get progressively worse. So A small leak would make sense.
    Ecky-Thump
    Agreed. Exactly the same symptoms. First actuation reasonably good, then deteriorating rapidly thereafter.
    Easily sorted.
    Turned out the hose needed to be threaded quite a bit further onto the barb.
    The “stop” point at the end of the thread was quite noticable in the end.
    b45her
    nearly all the problems with reverbs and avid brakes come from poor bleeding.
    just take the time to do it properly and both are bulletproof.
    dirtydog
    Last bleed should be done with the speed adjuster wound all the way out (slowest speed) otherwise it will be slow to return.
    theendisnigh
    bled it again last night, tightened the fittings, made more of an effort looking for stubborn bubbles, hey presto, its fine. Cheers.
    scaled
    Or a dodgy connection in your bleed kit 🙁
    Pook
    is the bleed easy?
    Ecky-Thump
    Yes Pook, the bleed kit is just 2 syringes to cycle fluid through the system a few times and as per dirtydogs reminder, the last bit is done with the speed adjuster wound all the way out.
    @ theendisnigh, glad to hear you’ve sorted it.
    agentdagnamit
    …therein lies the problems of Avid brakes.
The topic ‘struggling to bleed a reverb, any tips?’ is closed to new replies.
