Viewing 8 posts - 1 through 8 (of 8 total)
  • Stripping xt chainset apart?
  • jonny-m
    Anything I need to know, having a few chain skipping moments and I think it’s down to having a bit of dried grass stuck around the bolts. Is it a torx key or Allen key to undo the bolts. ?
    IamSam
    Torx……………………….you can do it with an Allen key but it takes ages and alot of swearing and you won’t be able to retention them after wards 😆
    bigyinn
    Torx if they’re the bolts that came with the cranks. Surely you can just firk the grass out with a small screwdriver?
    toppers3933
    if you can get the grass out without removing the rings then i would if i where you. getting them undone can be a PITA but getting them tight again without the proper tool to hold the back of the ring bolt can be even worse.
    Dickyboy
    Torx – and I think Shimano use a mile long bar to tighten them up at the factory too 👿 best get a piece of wire or screw driver to clean them out if you can
    jonny-m
    cheers guys, think i might try getting it out with a small screwdriver first, its pretty well stuck in there, can see it taking some time….
    PaulD
    Torx 30…..do not use a T25 as it will strip them.
    PaulD
    jonny-m
    managed to get it all out….. with an old knife and fork of all things!
The topic ‘Stripping xt chainset apart?’ is closed to new replies.
