Viewing 8 posts - 1 through 8 (of 8 total)
  • Stripping anodising?
  • thisisnotaspoon
    is it possible without dissolving the entire component?
    joolsburger
    Oven cleaner does the job beautifully.
    thisisnotaspoon
    oven cleaner = caustic solution?
    Thats just going to dissolve the alloy indescriminately isnt it?
    qwerty
    dishwasher
    cozz
    ovenpride oven cleaner work great
    mooman
    Oven cleaner? you got to be kidding.
    You would be better advised to rub it down than soak it in oven cleaner.
    Most bike frames and parts are poorly anodized with less than 10microns. Rubbing then down won`t take any time at all. And you will get the finish back – something stripping it with caustic wont do.
    tommid
    Caustic soda, takes about 25 seconds. I did it with some chainrings and cranks and then polished to a mirror shine.
    Drop me an email if you want me to talk you through it and send you the pics.
    takisawa2
    Thermal Deburring will do it. 🙂
    Cutting the frame into small pieces might be a faff though.
The topic ‘Stripping anodising?’ is closed to new replies.
