OK, this is project that I want to spend minimum on.
I got a steel jump frame for free last year as the seat post was stuck, I used the kit at work to heat it up and remove it and it took the paint off.
I didn’t care because I didn’t know if I would enjoy jump tracks or not…
I DO!
So, I want to give it some TLC before I start using it again this year.
My plan is to strip the paint off and buff it up with wire wool, then clear lacquer it and cover wear points with a funky coloured Fablon.
This should be pretty cheap, BUT all the reviews for the new strippers (eg Nitromorse) are rather poor.
So, can anyone recommend something cheap that does the trick, or do I ‘gently’ attack it with the oxy/propane again and take all the paint off like that?
Any advice from people who have done this would be great.
Cheers.
