I have a corridor added to the side of my house which is raised just over a meter off the ground, the house sits on a basement.
The floor of this corridor and the bathroom it connects to is a concrete beam construction ….if you can picture it it it is like an “L”shaped extension, corridor and bathroom raised off the ground by one meter.
It is sucking the heat from the house and always very cold and in winter and causes condensation.
So I want to insulate under this floor if i use panels its A, expensive and B,Will be fixed and i need access to pipe and cables that are below this floor, So how about packing this space with straw bales quite cheap 1 euro per bale easily removed for maintenance …
Is this a stupid idea ? the space is dry and enclosed so I dont see fire being a hazard but maybe I am wrong.
