AlexSimon – Member
Yes, but the strange thing is that missing 2km, so that meant it didn’t get a gps signal for about 15mins. I’ve never had anything like that.
That’s not uncommon, though. There are so many factors which can stop the GPS getting a good fix that it’s difficult to identify what in particular caused the problem.
With the disappearing segments and KOM thing, segments can disappear entirely if the person who created them decides to delete them or make them private, or if someone flags a segment as hazardous. Sometimes segments disappear from view but still exist and record; they show up as “hidden” segments on your ride and you can un-hide them using the website. No idea what’s caused this – it started happening more a few months ago. I think they maybe tried to automate cutting down on duplicate or “uninteresting” segments.
Unattainable high speeds sounds like GPS problems. Sometimes it lags behind for a moment, then suddenly jumps ahead as it gets an accurate fix, thinking you moved very quickly from A to B. Alternatively, if the GPS is sketchy then it jumps about a bit, adding distance (and therefore speed) over the time you were moving.
