After a week in Les Arcs (and 2 pairs of pads later!), I was inspecting the rotors and found some odd wear patters. They are Formula 180mm rotors (front and rear) with Formula THE One brakes, and Superstar red kevlar pads.
If you cross sectioned the braking surface of the rotor, you’d see it as being flat (where there are no vent holes), then a dip inwards (on both sides) where the first row of vent holes are drilled, then flat, then a dip again where the second row of holes are, and finally flat again.
This is same on both sides of the braking surfaces and front and rear. The pads also have the ‘wobble’ line to match the rotors!
Never seen this before. The brake surfaces on the rotors were flat before the trip and new pads were fitted (twice!) during the week, and bedded-in properly.
