There is a worrying tinging noise coming from my forks, as if there is something loose inside. The forks are Revelation U-Turn coils.
I noticed it whilst out riding the other day, it’s not happening when the fork compresses, only if you hold the bars and then drop the front wheel onto the ground if you see what I mean?
I also found the compression lockout doesnt work consistently, at first it was working fine, then i had the bike upside down to get the wheel out, but when I turned it back over the forks wouldnt lock-out, eventually they did, and the lockout now seems to function correctly.
My first thought was that I had ridden with the forks locked and somehow damaged the lockout, but the forks have a floodgate, so presumably even if I was riding with the forks locked out, and took a reasonable hit it would just blow open the floodgate, so wouldnt damage the forks?
Anyone experienced anything similar?
