1:1 ratio (for example, 32 front, 32 back) does ok for most things if you are reasonably fit and can put the power down steadily. I was running this all year as 9 speed, but I have just gone 10 speed 32 front and 11-36 back. The extra ‘underdrive’ gear is good when you aren’t as fit, have a sore knee, the going is draggy, you are carrying more stuff, it’s the end of a long day, and / or just plain steep.
slimjim78 – any clearance is OK as long as it clears the chanstay on a hardtail. However, you may want to look at your chainline and see which cog lines up dead on, and move your crank spacers if it can be improved.
I was running a BBG bashguard and a inner jumpstop on the 9 speed. Bash was good, jumpstop was rubbish. If you have room inside, a BBG bashwich is a good idea.
Since I went 10 speed, I opted for a Renthal chainring and the new XTR rear mech that has a clutch that keep the chain tight. I’mrunning this with no bash, jumpguard, or any other chain device ATM. Dropped the chain once so far at Glentress only, and I think I can make the chain shorter and tighten the clutch so may be good. Also it depends on your riding style, obviously big drops etc may need a more robust chain device than the mincing I do.
