I’m currently rocking some 5:10 chase shoes on the bike
and they’re just not stiff enough. Grippy enough, don’t look stupid but my feet ache after 5 mins continuous descending, let alone a 20 min DH/enduro stage 😉
What’s stiffer? I had my hands on a pair of Freerider VXi (or something) and they’re nice – not too bulky and at least a little bit stiffer. not sure about the slick portion of the sole though (but that’s been covered in another thread).
Are all the proper bike-intended 5:10s much of a muchness? What are your experiences/recommendations?
Are they the flat pedal type? I always used to swear by flat pedals until I got some minaars and platform spds. Transformed my riding it did and no more foot pain (as you described)
Anyway – that’s another argument. For stiffer flats, look at shimano AM-whatever-they-are. A fair bit stiffer but look a bit…special
bigger not thicker. If your pedal striking then the toes are probably next..
Some things to do – get stronger feet, do more descending stood up 10 mins is short, try some 30-40 min trails in the alps.
Love the Minaars and they do feel a bit stiffer, also all the big boys run clipped in 🙂
I’m quite happy not clipped in at the mo thanks 8)
I was going to post a link to the photos from the race at the weekend with half of the pros dabbing and slipping over the roots – but they are mostly clipped in 😐
I was very glad to be not clipped in for the first two stages FWIW. The Last stage would have been much of a muchness on flats or clips. About 200 m of pedalling but plenty of loose slidey corners to get your foot out for.
And that is the bit most people miss, when your good with them it’s as easy to remove/replace your foot 🙂
There was something on pink bike about clipped riders hitting things with more commitment and therefore needing less foot out stability too but that’s digressing.
On the other point what do you do to make your feet stronger?
Calf raisers over a step and moving up to doing them off smaller steps might help, I came to biking from climbing and found I never really struggled to stand for a long time back then, the less climbing I do the weaker my feet get.
I’ve never tried 5:10s but looking at that image, it looks like those chase shoes are designed to be flexible in the mid section (not surprising considering what they are designed for). Try some bike specific shoes as i’m sure they are more suited to riding bikes and will be still in the desired areas.
OP – If you are as serious about your riding as you make out then get some Five:Tens that are bike specific rather than use freerunning shoes !
I’m having much too much fun riding my bike around the woods to ever call it serious
agreed – when I bought these it wasn’t obvious that they weren’t bike shoes – it was only when I realised they were a bit flexible that I looked in to it. I’m just trying to do a little research before I spend $$$ on internet purchases (not enough shops to try stuff on in NZ) and find that there’s not much improvement.
Hey John, I’ve got the normal freeriders with some scholl/orthoheel ‘sports’ insoles, not so much for the suppourt but they do stiffen them up a treet.
The newer version of the Impact, the VXi, due soonish sounds like it could be right up your street. A good chunk stiffer than the Freerider range but nowhere near as clunky sized as the existing Impact.
