Formula B4 brakes, rear brake set up. Lever has an annoying problem that it doesn't return fully when released, and this causes the pads to bind against the disc. It can though be pushed away back into it's fully released position, and this frees up the pads.
My thoughts are a problem in the lever itself, rather than a caliper problem. Pads are relatively new, but the problem was evident before the pad change.
Anyone suggest what else I should be considering or doing? Not a big problem, just an annoyance.
