You might have better/cheaper sources to build a wheel, but 10% discount at Chain Reaction Cycles is now part of British Cycling membership (limited to one purchase per month?).
On the Custom Hope wheel builder, there were 3 RDS front Fatsno q/r 135mm hubs (can be had singly in clearance section for ~£45) and Stan Hugo 52s in all three wheel sizes. ~£170 before cashback IIRC.
http://www.chainreactioncycles.com/hope-custom-mtb-disc-front-wheel/rp-prod63716
Depending upon the fork you have, you would need to buy an RDS to FDS hub converter to use above wheel in an FDS 135mm q/r fork like the default Wazoo. You would not need to converter for an RDS Carbon Fatty fork.
http://www.tritoncycles.co.uk/frames-forks-c6/frame-fork-spares-c152/problem-solvers-fat-fork-disc-adaptor-p11825/
I use a converter to run my FatNotFat 29er wheels on my default Wazoo fork, as I still have yet to get round to fitting my £89 Carbon Fatty, which will drop my Wazoo down to ~9Kg total in skinny mode! 😳
