I’m guessing you have discs, in which case the well-respected ENO eccentric hub is out.
There are also bottom brackets to fit standard shells and Hollowtech type cranks which have a degree of adjustment through an eccentric thingummy
Bikemonger Charlie used to sell the exzentriker BB, but apparently the first few he sold didn’t go so well. There’s also the Phil Woods Philcentric, which is probably quite good. Neither have a lot of adjustment, and it may be that you have to use a half link to get perfect tension.
Both a good slice pricier than chain tensioners.
