Viewing 6 posts - 1 through 6 (of 6 total)
  • SS Fuel hubs, need a spacer for 10spd cassette?
  • thestabiliser
    Cassette s a bit rattly, got it as tight as I dare but it’s not nipping up the sprockets. Sunrace mx5. Or have I knackered the threads (probably).
    simondbarnes
    All 11spd road freehubs need a spacer (1.85mm) to run a 10spd cassette.
    edit: just checked the specs on the SS site – it’s not 11spd road compatible so shouldn’t need a spacer.
    thestabiliser
    MTB?
    simondbarnes
    MTB?
    Sorry, see my edit. More hubs are now coming with an 11spd road width freehub so assumed it would be this.
    thestabiliser
    Bum. That means I’ve knackered it.
    ajantom
    Nope, I have a set and the 10spd cassette fits fine.
    On t’other hand, tolerances on different brands can vary. So why not try a thin (1-2mm) shim behind the cassette, it won’t do any harm. The freewheel is steel is it not? So unlikely you’ve damaged that. Have you tried a different lockring?
The topic ‘SS Fuel hubs, need a spacer for 10spd cassette?’ is closed to new replies.
