The point here is that triples came about when mtbs were 5 or 6 speed so to get any decent range of ratios without massive jumps between gears, a triple was necessary.
Now that we're up to 9 or 10 speed, you can get near enough the full range (you normally lose the very top gear, maybe two but other than on the road, how much use does that really get?) and the right sized gaps between gears with a double so why would you then choose to have an extra chainring? Why don't we run 'quadruples' (I know they were available for a while way back in the early 90s but…) or 'quintuples'.
24/36 and 11-34 for me. A bit lighter, works perfectly and has better log clearance. Why would I go back to a triple?
