I have the X9 rear clutch derraliur which has the supposedly handy cage lock button.
I used it for the first time today after a particularly muddy ride so I could clean the Jockey wheels properly.
It locked out okay but I can’t get the little bastard to release. It’s supposed to just pop out when you move the cage forward again or with a bump, nothing’s working I moved it all over, tried to press the button back out from the other side.
It just won pop out. I can’t find anything on the net on it because everything just says it releases automatically when you get moving. So if anybody has had the same issue or tips on how to release the thing it would be much appreciated.
It may be seized on so I gave it a dose of wd40 but still no action, the unit is good condition.
