Resurrecting this from last week as I’ve now had chance to check out the problem in more detail.
Looks like my initial problem was my own user-error with a little bit of mad panic thrown in. On a second look, I found that the high/low limit screws were wound in completely to the extent that a few of the gears were unavailable. So I am getting the full range of gears after all. Its definitely a regular X5 shifter, not the Attack version.
I was really hoping to not overhaul the whole drive-train just yet. A friend has a Deore 10sp shifter I can try out with my 10sp SLX mech, but I’m guessing that won’t work too well with a 9sp cassette? Or will it shift ok up to the lowest gear and then just develop some slack in the cable where the 10th gear is missing?
Northwind – A very generous offer if its still available?
