Viewing 11 posts - 1 through 11 (of 11 total)
  • SRAM X1 1400 11S with 32T chainring, need a 28T ideally any advice
  • whatyadoinsucka
    i’ve bought a bike with 1×11 X1 sram direct mount 32t chainring x-sync (cassette 10-42t)
    and i’m considering a smaller chainring ideally 28t/30t so as to have a lower gear.
    I have a lot of climbs regular over 1000m and prefer to spin in lower gears to get up hills, than strain on a higher gear.
    choice seems limited for a 28T chainring , has anyone done it, and what did you buy
    how have people found loosing the lower gears, I’m happy with a
    24/36 = 0.66 lowest gear on my 29er hardtail, but that would mean a 28T chainring on the 42T biggest cassette cog
    bruneep
    RF direct mount 28t I’m content with that, I do ride proper hills mountains tho.
    #noshameinpushing
    benpinnick
    Weve done 28s. Works fine I think. The official chainring is very expensive, try this instead if I were you:
    http://www.workscomponents.co.uk/works-components-sram-gxp-fitment-narrow-wide-spiderless-chainring-963-p.asp
    br
    I’ve an Absolute Black oval 30T on my 29er, so a 28T one of them?
    Did you really mean 1000m climbs, or that you regularly climb 1000m (in a ride)?
    whatyadoinsucka
    thanks guys will look into the works, raceface and absolute, sorry i meant 1000m a ride, badly typed.
    M6TTF
    most of my rides are around 2500ft of ascent overall. I’ve got a 32T oval and never found myself wanting for lower. why not consider a 30T oval if you like to spin. Id imagine a 28T would be bloody miserable from losing the bigger ratios
    gaidong
    If you want a 28T that lasts forever (almost) – http://www.wolftoothcomponents.com/collections/chainrings/products/stainless-steel-direct-mount-for-sram-gxp-cranks-and-long-spindle-bb30. I have the 30T version in 104 BCD and it’s lovely.
    benpinnick
    SRAM do a steel one for £15 too. Finish isnt nearly as good as the WT but hey… its £15!
    gaidong
    Ben’s right, I forgot about those. Steel chainring for that money is a no-brainer unless you’re on a carbon feather bike.
    whatyadoinsucka
    Thanks guys yeah I think the sram reduced to £11.99 is fine
    http://www.chainreactioncycles.com/sram-direct-mount-steel-narrow-wide-chainring/rp-prod139307?gs=1&gclid=CK26oLzkgs4CFUs6GwodYDsAIw&gclsrc=aw.ds
    Just need to check 6mm offset, not sure where to look for that
    benpinnick
    AFAIK there’s only aftermarket 1 DM steel ring and thats 28T 6mm offset.
The topic ‘SRAM X1 1400 11S with 32T chainring, need a 28T ideally any advice’ is closed to new replies.
