SKF BXC600 ISIS BB
Probably the best ISIS BB there was ( Now just discontinued )
Triple sealing whick SKF reckon you can jet wash without penetrating and a quoted 10 year life span. Made entirely of stainless steel.
113mm spindle length, 68 / 73mm BB ( Standard size )
Been used on 3 short rides as new except from where the BB was greased when installed it dissolved the paper label on it.
Original box, instructions and spacer. £80 new.
£48 delivered.
http://www.bikester.co.uk/bicycle-parts/cranks-inner-bearings/inner-bearings/15407.html
http://www.mtbtandems.com/SKF.htm
Fox Spring New 450 x 2.8
This fits 2.5 - 2.75 stroke shocks.
Brand new taken from a new bike never ridden as not even close to my weight range , new price is £48.95
£25 delivered.
http://www.tftunedshox.com/Catalogue/Shop-Fox/Fox/Rear-Shock-Springs-Spare-Parts
Fox Van 36 soft spring,
Purple colour, used once as new, 2005-2010 models, 160mm forks, cost £25
£13 delivered.
http://www.tftunedshox.com/Catalogue/Shop-Fox/Fox/Spare-Parts-and-Springs
Gamut Chainring Bolts
Gamut bolts new but taken from a Spesh Evo, standard 9.5mm version, for use with bash guards. £8 delivered
Santa Cruz Seat Clamp 30.9mm as new unmarked £10 delivered.
http://www.stif.co.uk/mtb/product/santa-cruz-qr-seatclamp/7225
Formula Brake Rotors
Brand new 180mm and 160mm.
180mm £23 delivred
160mm £17 delivered
Hope Pro 2 Hub 20mm Adaptors
Brand new boxed £11 delivered
Sram X0 Grip Shift
As new used twice, RH only, £25 delivered
Salsa Pro Moto Bars
Near perfect, 31.8mm, 11 deg sweep, 660mm £30 delivered
http://www.charliethebikemonger.com/salsa-alloy-pro-moto-318-flat-xc-bars-1021-p.asp
Manitou Spyder + other models Soft Spring Kit NOS Brand New
For 98 model forks, may fit others hopefully the label may give you a better clue.
£8 delivered
Superfeet Black New Insoles size 4.5-6 ( Size C ) Cost £31
£15 delivered
http://www.wiggle.co.uk/superfeet-trim-to-fit-black-insoles/
