If the bike is new then most likely the gear cables are stretching at settling in, so the rear one has ended up a little bit slack.
Where the cable goes onto the rear mech its got a barrel adjuster… tey turning this a couple of clicks anti-clockwise (this’ll effectively tighten the cable). See if that improves it, remember how many clicks you do so you can always set it back, but it might take a couple more. If still no luck revert it back and just take it to someone in the know, it’ll only be this kind of adjustment thats needed.
