Hi all, hoping someone can help.
I have a 2016 Mondraker Foxy 2×10 with SRAM GX shifters and a shimano deore front derailleur and I cannot get it to set up correctly.
The issue is if i set it up in 1st gear (small c-ring and biggest sprocket) so the derailleur is just clear of the chain when i then shift into 20th (biggest c-ring and smallest sprocket) the cage of the front D is pushing the chain over towards the frame a lot. It simply appears that the cable doesn’t pull the derailleur far enough.
The limit screw isn’t preventing it swinging out further. I cannot seems to fix it.
Both derailleurs are shifting fine but it appears i can’t set it up so that gears 1, 2, 19 and 20 run without minor chain rubbing. I can get it clear at one end but then the other is seriously bad.
It’s a direct mount top pull derailleur. I have tried moving it up and down etc but doesn’t help. Have no idea what else to do (other than give myself a good excuse to but a new set of XT shifters :D)
It’s so frustrating has anyone had the same issue or got any advice?
Cam
