Hi all
On a ride last week and suffered a “gearbox problem” when ever I shifted up the lever would not click back into position as if the cable was slack.
So this week I removed my bar tape , opened up all the access areas on the shifter ( right side ,as always!!), removed the old cable and replaced lubing it up along the way.
The I got a cotton bud and tried to clean up as much old grease on the shifter while going thought the motions of changing gear…then regreased using finish line ceramic grease in a syringe whilst again going thought the gear change motions.
Anyway I put the cover plates back on and fixed the cable going thought all the gears….sweet….but the lever is still not going back into position when changing gear…….
The only thing I can think of is maybe use some 3in1 oil so that the parts I couldn’t reach get a lube on them!!
Any thing else I could do ….or have missed??
Thanks
