Hi all,
Can anyone tell me, apart from arm length and 24mm vs 30mm axle is there any differences between the sram carbon cranks?
E.g xx1 x0 etc.
I’ve got some sram direct mount rings that are boost (my frame is boost) and if I’ve got a gxp bottom bracket will all 24mm carbon cranks from sram fit ok or are some of them a wider axle to fit a different standard? Seem to remember DH cranks being a different width years ago but not sure now?
I’m sure I’ve seen some with a different Q factor to each other aswell, what do I want for a standard boost axel trail bike (yeti sb6).
Thanks in advance
