Viewing 10 posts - 1 through 10 (of 10 total)
  • Squealing brakes
  • pat12
    XT discs, really loud!! just started in the last few weeks
    Pads look pretty worn but not worn out will probably replace anyway, anything else to consider?
    Pat
    MartynS
    Contaminated disk.
    Loose bolts on the mountings.
    Clean the rotor, sling in some new pads and see what happens!
    brakes
    when you’re out riding stuff some wet mud into the caliper.
    it works, trust me.
    globalti
    If the brakes judder and make a horrible squeal as you roll to a stop, they are contaminated with oil. Clean the disc with IPA or glass cleaner and put the pads in the dishhwasher. Then look for the leak.
    pat12
    It stops well, neither lever is spongy – but both discs are as equally bad in terms of noise.
    will give the rotors a clean, i assume by IPA you don’t mean a pint of Greene King?
    curto80
    Muc-off disc cleaner on discs and pads. Repeat every few rides
    mattyfez
    If all is performing well, and it’s simply noise that’s the issue, find a nice long bit of gentle downward tarmac, get some speed up and burn them in.
    chestercopperpot
    Def not Greene King it’s only good for swilling drains out.
    ransos
    My XT brakes squeal very loudly in the wet, but are fine in the dry. Any ideas?
    brakes
    tighten all the bolts up, stuff mud in the caliper.
The topic ‘Squealing brakes’ is closed to new replies.
