Is it straight forward to take the covers off and pump more grease in?
For the main pivot it isn't difficult (if you have a workstand), however you have to remove the cranks and the front mech (well you do on my 2008 model).
just remove the pivot axle at the bottom of the seat tube on each side(there is a single small retaining allen screw which holds the pivot axles in place).
You can then get to the outside of each of the bearings (there is a small cover over the race which you can remove with small screw driver or tip of a blade.
If there is crap in there clear out as much as you can then add more grease.
