- This topic has 59 replies, 37 voices, and was last updated 8 years ago by nemesis.
Spoke tension gauge – worthwhile investment?
wanmankylungFree Member
I’m going to start building some wheels as I cant seem to buy what I want. Is a spoke tension gauge a worthwhile investment?
scotroutesFull MemberOnce you know what the right tension feels like you don’t need one.
Learning what the right tension feels like? Then it’s useful 😆
Fresh Goods Friday 696: The Middling Edition
Latest Singletrack VideosFresh Goods Friday 696: The Middlin...tomdFree MemberI got one of the Park ones for my first go at wheel building. I think it helped me get the tension right first time and also relatively even.
kcalFull MemberCan’t recall the advised note that a spoke properly tensioned will sound if plucked – but a mate built some wheels, and got his wife to record the correct set of notes for his ideal tension, so he’d know the right tension..
He did borrow my gauge later, too. Can be handy and useful to lend out.
LSFree MemberYes.
I’ve been building for 20+ years and can do perfectly fine without one, but it just makes life a little bit easier. Not so much for the actual tension figure but evenness around the wheel.wwaswasFull MemberAs a novice it’s great for getting even tension and making sure it’s ‘in range’ for the the rim and spokes you’re using.
STATOFree MemberYou dont need one but they can be useful. Ive built a few wheels without and a few with. Without came out straight and lasted. With came out straight and lasted, quicker build but saved time lost in checking with gauge and tweaking.
Where it rally helped me was awkward builds with light rims and spokes, meant you could see where the tension was off rather than trying to feel it, which was not as easy as a beefy build (since rim flexed less). Also good for checking existing builds to rebalance after some use (again, on light builds). Im not a pro so i dont get enough practice to learn by feel as well as some.
thomthumbFree Memberi’ve built about 10 sets of wheels without one.
The only time i could have done with one was my first road wheels; the rims flexed a lot more more and the spokes came undone. easily remedied. I should have checked them after the first ride; but i’d got a bit blase with 6 successful sets of mtb wheels.
thisisnotaspoonFree MemberIME yes, my first set of MTB wheels were fine for about 4 months then started to go out of true about the same time I was building a set of light road wheels. The road wheels were much much harder to build evenly, so I bought the guage, did it with that and they’ve been perfect (as have the subsequently re-tensioned MTB wheels and my 2nd and 3rd set of MTB wheels). So it’s possible without, but much easier and better with one.
I tried the tuning to an even note technique, but it didn’t work as at best you’re aiming to get all the tensions as close as possible as they’ll always be slightly uneven. If they were all perfectly even you’d use a tension guage to build wheels not a truing stand.
I found the best method was to thread all the spokes into the nipples equaly, then work round the wheel untill they were all ~5 on the park guage, coarsely true it (not forgeting to release any wind up each time), then ~10, coarsely true it, ~15, true it , ~20, then finaly true it. doing it in stages seemed to build up a much better wheel than just adding a number of turns at a time untill it was upto tension then truing it.
cynic-alFree MemberWhat njee said.
They can be useful for eg stans rims with tension limits but mostly they are used by folk who aren’t great builders or want to make themselves look good by using fancy tools
brFree MemberThe chap I use to sort out my wheels has one.
Does it for a living, and mainly a roadie – whether this makes a difference I’ve no idea.
bencooperFree MemberI have one. Never use it unless I’m building something with posh skinny spokes and alloy nipples.
roverpigFull MemberIf they were all perfectly even you’d use a tension guage to build wheels not a truing stand.
This is what I’ve never understood about a tension gauge. I’ve built a few wheels without one. Lace them up then adjust the tension to make the wheel true, round and dished correctly. So now if I go round with a tension meter and find the tension isn’t even what am I supposed to do? Adjust the tension to make it even and end up with a wheel that isn’t true? If not then what was the point of the gauge?
OK, I can see that it might stop you going too far and turning the rim into a pringle. But checking the note (using a free chromatic tuner app on your phone, for example) should stop that.
Not trying to be argumentative, just never worked out what the gauge was supposed to be for.
njee20Free MemberYep, that’s about it Roverpig.
Obviously you don’t want a wheel with vastly uneven tensions, but you’re never gonna get it perfectly even (and ridable), so assuming you can get it pretty close without a gauge, and you’re not wildly exceeding rim or spoke limits (and I accept it gives you an idea of where you are on that scale), they don’t really offer much!
scruffFree MemberI’ve built about 5 wheels now and I would like a tension gauge. I can never tell the sound by plucking them, i’ll pluck the same spoke twice and it’ll sound different to me, I think I’m tone deaf.
nikkFree MemberWhat a crock! Weird statements that reflect more on your insecurities than on how to build wheels.
Being able to know the actual measurement beats guessing 100% of the time.
Your generalization about “mostly they are used by folk who aren’t great builders” is bull.
And who the heck cares how they ‘look’ when building a wheel? I guess most people do it by themselves in the comfort of their own shed / workshop / home. They could be using pixie dust and dragons teeth for all anyone else would know or care.
nikkFree MemberThe point is you will be able to find out the average tension of the spokes, so you can tension them to spec. There is going to be some variance for sure, but at least you will be in the ballpark. Without that, you could be building the wheel with too much or too little tension, and not know until you start riding and breaking spokes etc.
njee20Free MemberWithout that, you could be building the wheel with too much or too little tension
But what is the ‘right’ tension? Yes some rims have a limit, but not all, or it can be very high, I’d not want to build a wheel to the maximum of many carbon rims. Do you get as close to the specified maximum as possible, or just enough that they’re not flopping about? What is that tension?
woodlikesbeerFree MemberI would say Yes and No.
It’s nice to have one to know what the spoke tension is. Especially if you have something like Mavic rims which are supposed to be built at 90 KgF. But once you have a good idea of what that feels like you don’t really need it.I tend to use the spoke plucking method to do the final tension. I would suggest paying the £9 and getting the Wheelpro PDF Wheelpro book It’s wheel worth a read and will save you hours and hours of rebuilding and truing.
thisisnotaspoonFree MemberThis is what I’ve never understood about a tension gauge. I’ve built a few wheels without one. Lace them up then adjust the tension to make the wheel true, round and dished correctly. So now if I go round with a tension meter and find the tension isn’t even what am I supposed to do? Adjust the tension to make it even and end up with a wheel that isn’t true? If not then what was the point of the gauge?
Unwind it and start again.
I’ve got a hypothesis how the physics and engineering work, as when I was building my road wheels (Stans alphas, pre the reinforcements, so prety weak) it was possible to build a perfectly true wheels, with tensions all over the place, and no ammount of faff would sort it apart from starting again. I suspect it’s because the rim is stiff(ish) so you could have 1 spoke doing all the work on one half of one side, and 7 loose ones (on a 32 spoke wheel), you could I suppose build a wheel with as few as 3 spokes on each side under tension, and the spoke on the other side wouldnt have to line up with it. Extrapolate that back to a more acceptably even tension and you can see how it’s possible to build a perfectly true wheel with tensions all over the shop.
Same with my MTB wheels, they were perfectly true, yet still went wonky. The next pair (built with nigh on even tension) haven’t moved a mm.
Based on that I’d say it’s possible to build without one, and some people can probably build very well without one. But I’d also say that even the most hamfisted person in the world could probably build wheels on a par with any bearded man in a shed who’s details you only get only after learning the secret handshake from the local cycling club, as long as he can folow the instructions. Because at the end of the day a perfect wheel is perfectly true with perfectly even tension, not much more to it than that.
billyboyFree MemberThe wheel build course I went on never mentioned their existence!
mintimperialFull MemberI’ve got one. I’ve not built *that* many wheels, so it’s very useful from a confidence point of view, and also handy for Stans rims, which have a lower max tension than most other rims.
It’s like most tools: yeah, you can build a perfectly good wheel with a spokey, a blob of bluetack and a biro, but it’s much easier with a stand, a dishing tool, some sort of nipple driver, and a tension gauge (personally I’d get those tools in that order, too, but everyone’s different).
mrblobbyFree MemberIf fairly new to it all (much as I am) then I’d say yes. I didn’t actually use it during the build process (followed Musson guide) but it was good to go around after and check the tension was even and in the right sort of range. Gives me a bit more confidence that I’d done an ok job. Next time I’d probably use it a bit earlier in the process too to maintain an even tension throughout the build process.
mathewshotboltFree MemberI’ve built hundreds of sets in my time and used a Dt Tensio for the majority.
Spokes, rims and in some rare cases hubs have tension ratings for good reason.
I consider it a great tool for beginners but it takes out all the guess work from building wheels properly for those with experience.
The plucking thing doesn’t work 100% of the time. I checked this theory once again last month to show someone. I plucked two spokes with the same tone but very different tension readings.
It is certainly possible to get a wheel round, true and dished with even tension (within +/- 5%) but this is made much harder with second hand rims or cheap parts.mathewshotboltFree MemberAnd re the previous question regarding a wheel being true but having uneven tension, I would suggest you take more time to build the wheel next time and de-stress the wheel properly. It may take a year or so to build truly great wheels and reduce the time period in which you do but its all about being methodical and careful.
OnzadogFree MemberI’ve got one and I use it towards the end of my builds. Just for my own satisfaction, I like to get them as even as I can. I don’t think they’re any good for absolute values but great for checking one spoke relative to another.
I checked the last wheels I let a local shop build for me. The tension was +/- 20%. My builds are +/- 5%. Both were true enough for the job but I know which I’d rather take on a weeks riding holiday!
nickcFull MemberI’ve never used one, and I’m not sure what I’d gain from it. As others have suggested, if the wheel is round and true and dished and the spokes are tight….what then?
I’m not sure what I’d do if I found all my wheels were all over the place tension wise though. 😆
orangeboyFree MemberI like mine. It’s makes for relatable builds and for me it’s the easiest way to get even tension quickly
Reliable wheels esp with light rims are about even spoke tension as much as tightness imoBut I build a lot of wheels and like shiny tools
PeterPoddyFree Memberif the wheel is round and true and dished and the spokes are tight….what then?
What then? How tight are they? Is it correct for the rim you’re using, or the spokes?
DB spokes deflect further for a given tension then plain gauge, and Stans rims build to a lower tension than Mavics for example.I use one every time, I’ve got my own, and I use one at work. IMO the Park one is cheap, easy to use and easy to read.
Yes I can build without one but I prefer not to these days. It’s a tool that removes doubt, I know tension is correct if I’ve used one, but I don’t get obsessed with it.
I’ve checked out a couple wheels built by experienced builders (I dunno if I count as that or not, I’ve probably built somewhere between 50 and 100 wheels) and one was dreadful. (That one came back for some extra work after the first ride) and the other was over tensioned.To my mind it depends on a few things:
Do you build LOTS of wheels? Like thousands? If so I’d expect you’d get to know tension pretty well by hand. I don’t need to use the reference table that came with the tension gauge any more most of the time. If you don’t build LOADS of wheels than you’re not gonna get that feel so easily.
Are you building wheels because you have to, or because you like to? I love building wheels! I get IMMENSE satisfaction from taking my time and getting a bit geeky with it, getting the spoking pattern correct (Symmetrical, reverse symmetrical, asymmetrical), getting the hub logo pointing at the valve hole, perfect dish, true and round down to 0.2mm (ish) and getting the tension even and right (1/2 turn extra on the inbound spokes chaps….) for the rim/spokeMaybe I’m OTT because I love it, but my wheels don’t come back to me so I guess I’m getting it right somewhere. 🙂
woodlikesbeerFree MemberI think it’s also worth mentioning that there are two priorities for building a good strong set of wheels.
1) Build the wheel with even spoke tension
2) Try and get it true and round.It’s “easy” to build a round, true wheel. It’s harder to build a wheel that stays as true and round as when it was built. If you swap priotrity one and two you get nice true wheels that buckle really easiliy.
Another thought – has anyone tried using a guitar tuner to get spoke tension even?
mathewshotboltFree MemberFrom what you’ve written above Peter Poddy, I think we’d get on well!
So many other shops that build wheels without giving thought to where the logo sits relative to the valve or even building them with rim logos (h+son for instance) facing different directions.
the details count
hatterFull MemberHave one myself (Park tool) and whilst I tend to build by feel I’ll always run the tension meter over any build before I consider it finished, a few times it’s brought something up that was worth tweaking. It’s like getting an independent second opinion.
Essential? No, useful and desirable for those who get satisfaction from a job well done? Yes.
The DT Swiss ones are serious tool porn as well.
thisisnotaspoonFree MemberAnd re the previous question regarding a wheel being true but having uneven tension, I would suggest you take more time to build the wheel next time and de-stress the wheel properly.
Nowt to do with making sure there’s no windup (presume thats what you meant by de-stress?).
Think about it another way, a 16 spoke wheel and a 32 spoke wheel, take all the tension off half the spokes in the 32 spoke and you’re still left with a perfectly true wheel, but with very uneven tensions.
Without a tension meter you’re guessing at how even the tension is, it’s not impossible, and some people are undoubtedly good at it, but with a gauge you can get it spot on every time.
somafunkFull MemberWheel building porn? – that has to include P&KLie – i have absolutely no need for such equipment but it’s very high on my list of wants.
I make do with an On-One Jobsworth dti stand and a park tension gauge, i have built without the gauge (built/repaired my own wheels since teenage years) but i prefer to use it, for repair of wheels i check tension beforehand then after repair, for new builds whether for myself or others i use it for my own piece of mind.
I mark the first spoke with tape, mark the rim with tape and an arrow to show direction of work round the wheel then attempt to build as true as possible with an even tension as possible whilst keeping a copy of the spoke tensions as i go along in my wheel building book that i’ve used for the past 20 years.
Probably overkill but i haven’t built hundreds of wheels to get the master intuative feel so it helps to follow a pattern that i’ve used for years – never had a failure due to my cack-handness yet so i’ll carry on. 😉
amack23Free MemberWhat’s the thoughts on a dishing tool. Required? Embarking on a first wheel build and have a tension meter ordered.
mathewshotboltFree MemberWe have a PK Lie stand but I still prefer the good old Kestrel as it is less sensitive.
bigjimFull MemberI’ve never used one, I’ve built 4 wheels so far and just doing the next pair this week. I’ll maybe take one to the bike shop to see what tension I do end up with, but my wheels have been great and straight so far, did have a derp moment truing one once but soon figured out I’d turned a spoke the wrong way.
I pluck the spokes to compare relative tensions by pitch, but don’t know how close I am to the rim limit of tension. I also go around plucking other people’s spokes (!), which has reassured me that my tensions are really even and high compared to most wheels out there!
eshershoreFree MemberI’ve built close to 500 pairs of wheels and yes I use a tension gauge to get it right each time – its a really useful tool even for an experienced wheel builder
Just built a new wheel for my own mountain bike this afternoon : Roval Traversee 29’er rim with DT Swiss Super Comp spokes with brass nipples on DT Swiss 350 freehub
Used the wheel tension gauge to get it really nicely balanced, rode the bike home tonight with the new wheel and it feels just right
The topic ‘Spoke tension gauge – worthwhile investment?’ is closed to new replies.
