Spoke length calculators ask for pcd, which is the hole diameter and can be found for most hubs, then centre to each flange. Some of companies tend to give flange to flange and offset, am I correct in assuming I then subtract the offset from the drive side on a rear hub and add it to the disc side?
ie F to F of 100 and offset of 10, drive side 90, disc 110
Then the opposite on the front, ie F to F of 100 and offset of ten giving disc 90 and 110 non disc?
Couldn’t they just give the data needed for the calculator?!
Also looking at buying some novatec hubs from australia, anyone bought anything similar? Any idea on customs charges if any?
Thanks for any help, had a couple beers and this is doing my head in!
