Viewing 5 posts - 1 through 5 (of 5 total)
  • spindoctor freehub removal
  • irish_chris
    Howdy folks,
    I’ve already broke one hex key trying to get the freehub off my halo spindoctor hub, any tips on how it should be done before i wreck the whole thing?
    I’ve got the hex-key-in-a-vice trick going, but what sense is the thread? And what side of the freehub do you remove from (i.e. drive or non drive)?
    Cheers,
    Chris
    daim
    Mine was a nightmare to get off. Used an 11mm hex key in through the drive side attached to a breaker bar. Mate of mine held the wheel while I swung from the breaker bar. Took ages to free but it finally loosened with a very loud “crack!” Spray some WD40 in there to help it out.
    Good luck! Thread is normal (Anti-clockwise removal from drive side.)
    irish_chris
    Cheers diam,
    Sounds like it’ll help burn off a few Yule induced calories.
    rockthreegozy
    get some plus-gas in there!
    goog
    stick it the vice and pretend your driving a bus doing a left turn
The topic ‘spindoctor freehub removal’ is closed to new replies.
