Viewing 4 posts - 1 through 4 (of 4 total)
  • Specialized Windpipe Shock/Tyre Pump
  • holyhutzpa
    Has anyone used one? Would you rate them, or would I be better getting a shock-only pump?
    Thx.
    Del
    if you need a shock pump, get one, and if you need a pump for your pack, get a topeak morph. the spesh is ok, but is a compromise. you can probably pick up a shock pump for 10-15 quid on here. try a WTD ad.
    RichPenny
    Had one, it wasn't the best at either job tbh. You don't need a shock pump when riding usually, so get a mountain morph as above, they're ace!
    holyhutzpa
    Mountain morph looks ACE alright!
    In a typical kind of fashion, I'm in Ireland and need one last-minute! So, in the pure shock front I've a choice between getting the Specialized Shock Pump or the Halfords one!
The topic ‘Specialized Windpipe Shock/Tyre Pump’ is closed to new replies.
