also the forks and brakes were not suitable and the rear shock got so hot you could not touch it.
fair enough and interesting. It seems Specialized are addressing ^^ by using 200mm rotors front and rear whilst the new fangled front wheel spacing fork, according to the review, is stiffer than the pike.
Northwind – no weight mentioned, speculating but presumably specialized wouldn’t let it be published. Edit – prior article on the same site suggest rumours of an s-works version sub 20kg so assume the one pictured is 22kg? 2kg for a whole load of carbon bling probably fair given it already had carbon wheels.
