Northwind/njee/ruscle, tried to get the bearings out of my rear hub the other night (in admittedly a short space of time) but couldn’t budge them! Thankfully they still roll ok if a little gritty, but once I’ve pulled the freehub off, which side do I attack the axle from to get it out, and is there a preferred method of doing so?
To the OP, if its the front hub bearings you need to replace, you need 1x 6804RS and 1x 6805RS. Any good bearing suppliers should have them, and they won’t be much more than a couple of quid each. As others have said, just buy the cheap ones, on an MTB expensive bearings just aren’t worth it.
Ruscle, have you possibly got drawings for the nylon tools you have had made?
