Viewing 15 posts - 1 through 15 (of 15 total)
  • Specialized fox triad shock?
  • Danno72
    Got a mate at work who has had problems with his shock and had it repaired in the shop a couple of months after purchase of the bike. It’s a 2010 Stumpjumper comp. Now it has broken again. Question is, should he try and get it fixed or just get another type of shock? Are these shocks known for problems? Can you fit a RP23 or similar on to this bike? What options does he have?
    Dan
    LoCo
    what was wrong with it? can’t have been that bad if the shop fixed it.
    The RP23’s are better shocks.
    stevious
    Already sent mine (from a Stumpy 2010) back to mojo for repairs once since sept.
    Speshpaul
    Ask to have it sent back, it should still be under warrenty or pretty near which is normally enough for spesh to sort it out.
    jhw
    I have a friend whose Fox Triad on a 2010 Stumpjumper got stuck down (it was very cold at the time).
    Can you keep us posted on what happens with your mate?
    Sounds like a possible bad batch?
    This is unacceptable. You read too often on these boards about “bad batches” coming out of Fox or wherever. It seems like 1 year out of every 3 is just a “bad batch”…sorry!
    Danno72
    The shock has lost all fluid and air. Whats the difference between the specialized shock and an rp23? Will an rp23 fit in to the frame?
    bigyinn
    Stuck down can be an issue in cold temps, because the rubber seals can stiffen, air can get by them, causing stuck down shocks.
    stumpy01
    MBR had a 2010 Stumpy FSR Elite & their Triad lost all it’s oil & subsequently damping.
    They had it sorted by Fox.
    Mine was fine in the 8 months or so I owned it until they replaced it with a Brain when they warrantied the frame (paint defect).
    LoCo
    Rp23 has 3 propedal settings and p.p on/off switch. As opposed to the triads set pp, open and lockout. different internals.
    The length may mean Mojo have to build you one with a different bodytube due to lower mounting.
    Send back to Mojo for warranty and ask them about possible custom build rp23.
    abductee
    Same here, 2010 Stumpjumper 5 months old, Triad, cold weather, oil leaked out of the adjuster. I’ve sent it back to the shop so it might get fixed under warranty.
    They are quite different to normal shocks so I reckon it would be difficult to replace it with somthing else unless parts were interchanged with another model to create a frankenshock.
    The RP2 on my previous bike also leaked air after about 3 months but the replacement has held up OK.
    bigyinn
    Yes, spesh do like their non standard length shocks dont they,
    amt27
    Got an 8 month old Stumpy comp, not had a problem with it, although it’s not a great shock.
    You couldn’t upgrade to a RP23 anyway, as the Triad doesn’t have a bottom eyelet, it bolts onto the linkage, any RP23 you buy would have an eyelet.
    A few people on MTBR used to upgrade their 08-09 Stumpies to RP23, they had to get the shocks adjusted by Push, Fox now supply the RP23 in the correct size.
    spacemonkey
    Call Spesh CS and run it past them. They’ve always helped me out in the past.
    020 8391 3500
    LoCo
    It is changeable to an RP23 it’s only the body tube that needs to be changed, a fairly basic job, unfortunatly Mojo don’t supply any parts to anyone else.
    Danno72
    Thanks for all the replies guys. I’ve passed them on tho my mate and he is going to call Mojo and see what happens.
    Dan
The topic ‘Specialized fox triad shock?’ is closed to new replies.
