Just bought a 2010 enduro frame, which unfortunately didn’t come with a headset.
The bearing cups are integrated into the frame.
Initially I’ll be using non tapered forks which have the hope adaptor fitted to allow for a tapered headset.
I’m not sure what I need to do to get the headset sorted, as I’m not sure if the bearings are 45/45 deg or 36/45.
I need a 1 1/8 bearing and cap etc for the top and a 1.5 bearing and crown race for the bottom.
I’ve already got a 1.5 hope crown race which I’d like to use.
And I have the special Specialized spacer which is needed to lower the bottom bearing in the frame.
I was thinking that this might work.
Superstar headset
Has anyone been through this, if so what did you do.
