I have a 2013 Specialized Camber 29 Carbon with 110mm Reba RL, which has been a great fork for my ageing lardy body. I tend to ride cross country and trail, no jumps, a bit of technical, small drop offs etc. no intention to race.
My challenge is I bought some new DT Swiss Tricon wheels with 15mm front axle so need to upgrade fork to use 15mm axle, deliberate choice as wanted to stiffen front end and do justice to the wheels.
I really like Rockshox forks and run RCT3 revs on my 26 Stumpy which are brilliant for how I use the bike, also prefer maintenance schedule over Fox. The trouble is if I want RCT3 I only have the choice of the SID with 120mm travel or possibly pay to get some Revs reduced to 120mm.
So need some advice please
Will it be ok running 120mm on the Camber accepting slight change in geometry, height rise and some slackening of head angle. Specialized allow 10% increase to maintain frame warranty.
Will 2013 SID be ok as general fork, concern that is primarily racing fork however I can get a new spring assembly to reduce travel to the correct 110mm – more cost. I have reserved a 2013 SID for Christmas – bless my better half.
Hold out for 2014 Rev RCT3 and get it reduced to 120.
Advice thoughts eagerly sought – preferably polite please.
Thanks in advance
