Long story short: I did some electrical work and now my RCD is randomly tripping. What have I done wrong?
Long story long: first day of the holidays so time for some DIY bodgery.
In the eaves cupboard in the attic there were mains cables hanging down joined with terminal blocks to wire in a socket. Bit shoddy looking.
I was concerned that these might get snagged when chucking stuff in the cupboard or could even potentially short on something metal so I decided to replace them with a proper junction box and neaten up the wiring.
I flipped the breaker for that circuit and confirmed it was definitely dead first with a lamp and then with a circuit tester in the socket and then directly on the wires themselves. Then finally the good ol’ tentative back of the hand. All good.
But shortly after, while installing the new junction box, the main RCD tripped. 😕 No idea why or how anything I was doing could have tripped it. Capacitive current from my body maybe?? I wasn’t wearing a nylon shell suit or anything.
Anyways, I finished up, reset the breaker and the RCD, checked the socket still worked, and everything seemed good.
Then at 2am, about six hours after I finished this work, the main RCD tripped again. I reset it and went back to bed. It tripped again some time overnight.
It’s back on at the moment but I’m just waiting for it to go again.
Question is: what the hell have I done? It wasn’t exactly complex electrical work. Not much more than wiring a plug. Can’t see how I could have got it wrong.
Correct. I flicked the individual breaker for the circuit before starting work (marked 2 in photo), but while working the main RCD (big one at the left) tripped for some reason.
Yeah, the breakers just disconnect each live circuit, the neutrals are all on a bus together so if you short any part of that bus to earth, the main RCD will trip.
Based on the work done I think the most likely explanation is that you’ve got an exposed earth wire very close to an exposed neutral. (Could be a cut in the insulation where the wired have been stripped)
I’d whip the covers off the junction box and socket off to see what you can find.
If all’s good inside both you could be looking at an internal cable fault on one of the sections you’ve manipulated
Well it didn’t trip again but I don’t trust it.
So I took the face off the socket and rechecked the new junction box just to make sure. All good.
I bought one of those cheap socket testers from B&Q and it gives the socket the all clear BUT interestingly reports a missing earth on other sockets in the attic! Yikes!
My little circuit tester shows good continuity on the earth going into and out of the junction box. So the “disturbed some other unseen wiring” theory is looking plausible. (Or they were just never wired properly in the first place!)
Now I have to spend all day reshuffling the attic to get decent access to the other sockets. 🙁
One of the other sockets also had dodgy wiring. Presumably to save on the exorbitant cost of a nice safe junction box, the muppet just had three cables going into one socket (main in, main out, plus a spur to another socket).
Stuffing the resulting nest of wires into the back of the socket damaged the earth wire which sheared off.
So three double sockets on that side of the attic had no earth connection 😯
All ripped out now and replaced with a proper separate junction box and single spurs to the sockets. And unsurprisingly the socket tester is now much happier.
