One thing to consider with the Solaris is rear tyre clearance. Its not bad, but its not anywhere near being able to clear a 2.4 ardent like its claimed, at least not with a 23mm internal width rim. Even with a 2.25 michelin wild race’r the clearances are marginal and I could get the rubber to touch the stays on both sides with what I consider acceptable flex from the wheels.
I’m 14.5st running a large and found that I can’t run a nice wide tyre, which means I can’t run the lower pressures I prefer without cutting right through tyre carcass. With the higher pressures I need to prevent the cutting, I’m not achieving the ride quality from the bike, notably traction on slow speed rock and root crawling on difficult and thrutchy climbs. It shows its self in other scenarios too, but the big issue for me is the specific one noted above.
This is my only negative with the bike. Its an otherwise excellent, careful considered and well designed and constructed set of pipes. Sadly, because I can’t achieve what I want, I’ll be selling in in a few weeks.
YMMV
