• This topic has 21 replies, 20 voices, and was last updated 8 years ago by Shred.
Viewing 22 posts - 1 through 22 (of 22 total)
  • Someone explain why it takes so long for temps to increase after mid winter
  • flanagaj
    I have never fully understood why it takes so long for temperatures to increase after December 21st. We are effectively 3.5 months our from the shortest day and it’s only 10-12c, yet if you go back 3.5 months from the shortest day you are in mid September and temps are much warmer then.
    Is it solely down to the temperature of the Atlantic being cooled so much during the winter months?
    djglover
    Earth tilt
    scotroutes
    10-12c? It was (literally) freezing here yesterday 🙂
    flanagaj
    Earth tilt
    So does that mean although the days are just as long, the sun strength is actually weaker than at the same time in Autumn?
    10-12c?
    Yep. It’s a balmy 10-12c down here on the south coast.
    teef
    The earth is like a giant storage heater – it takes a long time to heat up and to cool down. That’s why it’s colder in January & February than December as the cooling takes it’s time. Similarly in the Summer – July and August are usually warmer than June.
    thecaptain
    Teef is right, but more precisely its mostly due to the thermal inertia of the oceans.
    peabrain
    I’m with scotroutes – 12 degrees!? We had days colder than that in July last “summer”.
    dannybgoode
    Global warming…
    rOcKeTdOg
    12 degrees? I’ve just scraped the morning snow off the car here in the midlands!
    fasthaggis
    It’s all linked to Winter pothole size and people whining on about the state of the country.If there is enough of them,then their gloom and dullness keeps the temps down till May 😛 😈 😆
    joshvegas
    I blame Maggie Thatcher sucking the warmth from the ground to line her own coffin.
    The cold is fine i just wish wiuld dry up.
    wolfenstein
    Midlands is 2degree this morning..i will happily embrace 10-12 with no wind any day.
    singletrackmind
    Coz we are an Island?
    The sea is billions of gallons of cold water.
    Takes weeks to cool down, and weeks to heat up.
    The prevailing winds blow over the Atlantic and the cold sea cools them down.
    When the Gulf stream is in full effect and the sea water temp goes up by 9’c the air is also warmed by this.
    Some or none of the above may be true. IANAM
    Frankenstein
    Concentration of electromagnetic spectrum not as concentrated and axis angle of the Earth.
    Nothing to do with distance.
    Combine that with weather and being on a island.
    Or it’s just 5hit and appreciate the good weather.
    At least no malaria or too many poisonous bugs.
    bruneep
    That is a summers day here, today’s conditions
    singletrackmind
    When the sun is low on the horizon the UV power is massively reduced as it has to cut through the atmosphere at a shallow angle, making the atmossphere thicker and depleting the radiation.
    In summer when the sun is high in the sky the UV rads hit at a much steeper angle so the atmosphere sort of thins , making it hotter quicker.
    Think sloping tank armor for a simili ( sp )
    Dibbs
    It was trying to snow on the Quantocks at half ten this morning. 😕
    ampthill
    The tilt of our orbit and low angle of the sun explain why the energy input to the Norther hemisphere is lowest in midwinter. But that doesn’t explain why the coldest days are after the 2st December
    In December the Northern hemisphere is loosing heat faster faster than it the sun can replace it. It looks like this is true until late January. At this point we start add heat faster than we loose it. But things aren’t changing very fast. By the equinox, 20th March, the sun is increasing the rate at which we add heat at the greatest rate.
    mattyfez
    Because science.
    You’re welcome 😆
    I actually bought a copy of new scientist super space edition or whatever.. Very interesting.. The sea actually regulates the temperature of the land, if we had less sea, we’d see much more violent swings in temperature.
    footflaps
    But that doesn’t explain why the coldest days are after the 21st December
    Takes time for the sea to cool off / warm up around the UK, warmest/lowest sea temp lags longest/shortest day by about 2 months.
    Shred
    From what I understand, the earth is always radiating heat. After the 21st Dec, the earth is still radiating more heat than it is gaining from the sun. I think it is something like the 10th Jan before the northern hemisphere is gaining more heat than it is expelling. This then takes time to warm up the earth, so the earth is net gaining heat after 21 June, so it stays warmer into Autumn.
The topic ‘Someone explain why it takes so long for temps to increase after mid winter’ is closed to new replies.
