next project. replacing a 1930s toilet. Has the original lead pipe feed up to a high level cistern. replacing with a modern cistern so need to modify the water feed.
can’t easily replace the whole feed as it is embedded into the wall right in the corner and travels vertically to the old cistern. looked at an option of a self cutting isolating valve to create the new connection then cap the top off, but looks like I can’t get behind the pipe without bending it.
What other options could I use? plan to use plastic push fit. just saw off the end and some sort of compression fitting?
We’re lead pipes a standard diameter?
