Hello STW PC boffins. I've got a couple of questions that I hope you can clear up for me.
Firstly I have a laptop which is dual boot – xp home for general and internet stuff, xp pro for audio production. On both boots things run incredibly slowly. This particularly obvious when switching between open programs (that never used to be the case with same programs) and when copying files from one folder to another (any type of data). Is this my hard drive failing? It's a four year old Acer laptop that was crashing a lot a while ago and each time would perform disk check on reboot – I believe this puts strain on the disk and reduces the lifespan.
I've recently had an external disk which I formatted with Paragon Hard Disk Manager after the Windows tool couldn't do so. I then had similar problems of hanging going into folders and not being able to copy so I presumed that disk is trashed.
Last question.
My desktop PC is also dual boot (same set up as laptop – xp home/xp pro) and I'd like to try Windows 7 (64 bit). Is there any issues just adding windows 7 and having a triple boot? The XPs are on a partitioned drive and Windows 7 would go on a separate drive.
