I bought all the stuff needed, solder, wire wool, flux etc, then walked into B&Q and found pre-soldered fittings…doh! You will also need some sort of propane torch that use coloured cylinders about 30cm long…I have one from work but if you are buying, do a little research as some are more suited than others I believe.
Its easy, just do a little google on the technique. Top tip I was given for repairing pipes that are dripping and therefore wet…shove some bread up the pipe as it will soak up the water enough to keep the pipe dry, but it will quickly disintegrate afterwards and fall to bits. Might want to take the strainers off any taps and remove the showerhead just to be sure though 🙂
