Right folks, last year we had a new main pressure (unvented?) HW tank fitted as part of a major reburb.
I'm now thinking about adding solar panels, but I'm not keen on changing the HW tank.
I know that a traditional solar system uses a tank with two feeds – one from the CH and one from the Solar panels.
Is there any reason why you couldn't just use a single inlet with valves to switch between the panels and CH?
In my head I have an elegant solution using temperature sensors in panels to switch the control valves.
I'm guessing that one issue could be the use of antifreeze in the panels? Would that bugger up the HW loop from the CH?
Whaddya think?
